I already tried to reinstall the Source and it works fine if I do it from scratch. But when I reimport my backup file it totally goes bezerk
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Data.OleDb.OleDbException: The Microsoft Jet database engine stopped the process because you and another user are attempting to change the same data at the same time.
at Plugwise.Core.PWCore.InitDatabase()
at Plugwise.Core.PWCore.Init(Boolean threads, Boolean storage)
at PlugwiseUpdate.MainForm.MainForm_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
PlugwiseUpdate
Assembly Version: 2.0.3426.37553
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/PlugwiseUpdate.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Plugwise.Core
Assembly Version: 2.0.3426.37535
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/Plugwise.Core.DLL
Plugwise.UI.Wizard
Assembly Version: 2.0.3426.37543
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/Plugwise.UI.Wizard.DLL
Plugwise.UI
Assembly Version: 2.0.3426.37538
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/Plugwise.UI.DLL
Plugwise.Util
Assembly Version: 2.0.3426.37526
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/Plugwise.Util.DLL
Plugwise.Debug
Assembly Version: 2.0.3426.37527
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/Plugwise.Debug.DLL
Plugwise.Dal
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/Plugwise.Dal.DLL
Plugwise.IO.Remote
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/Plugwise.IO.Remote.DLL
Plugwise.Net
CodeBase: file:///C:/Program%20Files/Plugwise/Plugwise%20Source/Plugwise.Net.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
