Hello can anybody give me a hint on how to reset a merten universal dimmer from the merten connect range type 507900.
The in the manual mentioned procedure doesn't seem to work! Clicking the program button 3 times and then hold it for 5 sec!
Is there any reason it doesn't go back to factory default or am i doing it wrong. I hope someone can be of assistance.
Erwin
Edit / turns out that there is a small tool available that alows one to reset the devices via pc-z wave dongle. So problem solved
Trouble resetting Merten Connect dimmer
- Willem4ever
- Global Moderator
Where did you find this tool ?
This works over here, did this several times with the Merten stuff
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by pe2six</i>
<br />Hello can anybody give me a hint on how to reset a merten universal dimmer from the merten connect range type 507900.
Erwin
Erwin
