Visonic Powermax+ and X10
Moderators: Rene, Willem4ever
Hi All,
When I turn off the alarm there is always a X10 signal send
House Code + Turn off all units "H1 (?) H All Units Off".
I can't find any Turn off in documentation or settings.
how can I disable this?
all the settings in turn off alarm are set to do nothing.
If I remember correctly there is no direct turning of, just delete all the entrys.
the settings for the X10 Code H1
all of them is set to "niet actief"
AAN TOTAAL
AAN DEEL
AAN UITSCH
AAN ALARM
AAN VERTR
AAN KEYFOB
AAN ZONE
Can the Powermax plus send all units off?
I will recheck everything..also the RFXcom.
b_weijenberg
Post by b_weijenberg »
is the house code set to G?
If so the H1 off is standard sent to switch of the sirene
Bert
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by b_weijenberg</i>
<br />is the house code set to G?
Bert
Bert,
House code is set to H
I have no X-10 Sirene
The command for the sirene must than be House Code I unit code 1 off and not all units off
Enver
b_weijenberg
I've checked it with my system and you are right.
The panel transmits an All Lights Off if the panel is in the disarmed state and a disarm command is given. This seems to be a bug. I couldn't find any setting in the alarm panel for this.
If the panel is armed and the disarm button is pressed no All lights Off will be send. Only that unit is switched off that is programmed to switch off if one or more are programmed to switch off.
Bert
<br />I've checked it with my system and you are right.
Bert
Bert,
Thank you for checking and confirming.
Powermax is switching some devices of that I don't want.
I will put the other devices under another house code.
Enver
This is working different for me, I have the one of the first Visonic Powermax alarm panels.
What I know is that the firmware part on the X10 control is not very stable. I had a lot of problems to programming it. I installed now that I only get a x10 signal when the alarm goes Of and On. It seems that Visonic is still not able to do a good job in the new versions of the panels. If you google on this subject you will find a lot complaints as well.
I have the firmware “F” form march 2006. This is the latest available one for the powermax plus
In few weeks there will be a new model of the powermax available and also the webinterface.
I hope that the webinterface will have more possibilities. For total controlling
Enver
Do you mean that there will be a Visonic Powermax alarm panel which has a network port and a build in webserver. Or some additional device.
The new model is called Powermax Pro
with this model you can integrated a module called Powerlink.
This module will have a built in web interface for monitoring controlling via web
for the existing Powermax there will also Powerlink avalible.
for more information look at the site
http://www.waakzaamwonen.nl/catalog/pro ... tarterskit
