Autogordijn - working any good?
DJF3
Post by DJF3 »
It looks like this 'autogordijn' (http://www.autogordijn.nl/index.html#_Prijslijst) works with KAKU and can therefore be controlled using RFXCOM & HomeSeer.
Does anyone have experience with this solution? What's the quality?
The website gives a lot of information. They are a lot cheaper than Harrison (who's probably better)
This could however be a simple integration for a low price.
/DJ
(I don't have any curtains in my home , [:)] but that's a different problem that can be solved)
Snelvuur
Post by Snelvuur »
Beside that i think this part is english..
Lempens found it working "ok" http://www.domoticaforum.eu/topic.asp?TOPIC_ID=3207
However, chak was not that eager http://www.domoticaforum.eu/topic.asp?TOPIC_ID=736
Harrison works much better...:)
My problem was the hickups when crossing the different elements.
Paul H te O
Re: Autogordijn - working any good?
Post by Paul H te O »
I use a simmulair curtainrail for a few years now, it works good.
The good thing I also like about this type of rail is that u can open or close it manual as wel.
Regards Paul.
Reason: rewrite in english please
HS4 Windows 10 Pro
Phaeton
Post by Phaeton »
I have a simmilar curtainrail. Like enver told it sometimes has a small hickup. I have filled up the gap with some vaseline, problem solved (works now for three months). This week irtrans will arrive and i hope that this can contol the curtainsrails.
groeten,
Peterpc
Post by Peterpc »
I have one and had the same problem when opening and closing the curtain. Rubbing a candle over the rails solved the problem.
I bought mine here:
http://www.degordijnenwinkel.nl/info/el ... -1604.html
99 euro.
Peter
http://www.pcgsm.nl/
