- 2 x Sony EVI-D30L PTZ camera
- 1 x Convision V-200 video server
Uiteraard inclusief alle voedingen, baluns, 2 x Visca stekker (als ik de 2e nog terug kan vinden), boekjes/CD Convision, enz.
Zelfs de coding voor de Visca PTZ-besturing doe ik erbij [:p]
Alles in 1 koop: 300 euro.
Komen kijken is geen probleem, dan kun je jezelf overtuigen van het perfecte beeld dat je met deze camera's krijgt.
Hier wat extra info over de camera:
Specificatie:
Model Description:
Color PTZ Camera (fewer functions)
Model Details:
Lower cost version of the EVI-D30C by eliminating functions, omits the AT and MD, A/V out, RS-232C out, as well as other functions
Features:
High Speed, Wide Range Pan/tilter
X12 Optical Zoom, High Speed Auto-Focus Lens
6 Position Preset
RS232C Control Input Terminal
This function automatically controls the zoom lens to ensure that the size of the subject remains constant on the screen.
The EVI-D30L employs the auto exposure and advanced backlight compensation systems to ensure that the subject remains bright even in harsh backlight conditions. Because the subject position is know a comparison can be made between its brightness and that of the background and the camera subsequently adjusted to compensate for the conditions.
Video Signal: NTSC
Image Sensor: 1/3" IT Color CCD
Effective Pixels: 768 (H) x 492 (V)
H. Resolution: 460 TV lines
V. Resolution: 350 TV lines
Lens: X12 Power Zoom, ~f=5.4 to 64 mm, F1.8 to F2.7
H. Angle of View: 4.3 (tele end) to 48.8 (wide end)
V. Angle of View: 3.2 (tele end) to 37.6 (wide end)
Shortest Subject Distance: 10mm (WIDE end), 800mm (TELE end)
Min. Illumination: 7 lux F1.8
Illumination Range: 7 to 100,000 lux
Auto Exposure: Auto Iris, AGC
Shutter Speed: 1/60 to 1/10,000 sec. (VISCA™ control)
Gain: Auto/ Manual (VISCA Control)
White Balance: TTL Auto Tracing/ One Push Hold, Indoor Preset, Outdoor Preset (VISCA control)
S/N Ratio: more than 48dB
Pan/Tilt: Horizontal 100 (Max speed 80/ sec),Vertical 25 (Max speed 50/ sec)
S Video Output: 4 pin mini DIN
Control Terminal: RS232C, 8 pin mini DIN, 9600bps, Data 8 bit, Stop 1 bit
Power Requirements: DC12 to 14V
Power Consumption: 11W
Operating Temperature: 0 to 40C
Storage Temperature: -20 to 60C
Dimensions (W/H/D): Camera 142 x 108.9 x 159.9 mm
Weight: Camera 1200g
Dit topic eindigt al een hele tijd met een PM waardoor de indruk kan ontstaan dat er iets verkocht is, maar dat is dus niet zo. De 'reservering' is (sinds een weekje of zo) opgeheven.
