My first webcam... test it please...
Moderator: Esteban
I just finished setting up my first experimental webcam.
It's a combination of BDLCAM and WebcamXP running on W2K3. You can find it at http://www.hekkers.net:800. Primary concern i have right now: do i need to upgrade my upstream or does it look ok?
Robert.
PS.
Not 100% sure i configured my firewall right, so if it doesn't work, sorry....can't test that from 'the inside'.
Robert.
PS.
- Willem4ever
- Global Moderator
It says contacting server, but no picture appears. I guess you have to open some more ports on your firewall.
It's working for me now, what a mess in the room
When I came on the cam the backlight of the camera was on, don't use this standard (or somebody else put it on?)
Works good, the quality of the Sony evi-d30 cam is really good.
What is your upstream right now, for now with one user it looks sufficient.
- Willem4ever
- Global Moderator
<br />It's working for me now, what a mess in the room
Works good, the quality of the Sony evi-d30 cam is realy good.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">That could have been me i pushed some buttons ...
Ok I thought so
I program my backlight that it is set back to original setting after 1 minute or so.
Do you have a image now Willem.
- Willem4ever
- Global Moderator
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by willem4ever</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Bwired</i>
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I'm using Safari on a Mac, and that doesn't work, with firefox I do get a picture, Indeed this rooms is a mess.
Robert,
It's really time to install the water pulse meter you bought a long time ago
I also see a fire alarm sensor, a special Visonic PIR sensor, a xanura module, a marmitek module etc [:D]
Your room looks almost the same as mine, also a lot of stuff!
Pieter
Pieter
Robert,
I can't access it form my work...firewall is blocking it..
on my remote PC there is no Java..
will tray later
Is there a PocketPC plugin with you software that you can access it form the mediaplayer?
Enver
will tray later
Enver
<br />Robert,
will tray later
Enver
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">When I'm at work i have the same problem, blocking allmost every port!
Beside that you need a java client, if you can install this on your PC or PDA etc it should run.
http://www.java.com/nl/
<br />Robert,
will tray later
Enver
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yeah i know...too late to start cleaning last night... i'll notify my wife [:D]
<br />What is your upstream right now, for now with one user it looks sufficient.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Currently i have 4096/1024 (XS4All Only Lite).
Robert.
Robert.
<br />Robert,
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yeah i know...i know... it's all a matter of time...
<br />Robert,
Your speed is good, 1024 upload is almost the highest speed you can get with ADSL.
I'm running on two of those ADSL lines, within a few months I get SDSL 2mb Up and Down with no overbooking
Let's see how that is running.
<br />Robert,
will tray later
Enver
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Not that i know of, i'm kinda new to this Webcam stuff, but i'll have a look in the evening.
Robert
<br />Robert,
will tray later
Enver
Robert
- Snelvuur
Speed is good, i only thought a bomb was exploded in the room
- Willem4ever
- Global Moderator
<br />Your speed is good, 1024 upload is almost the highest speed you can get with ADSL.
It's good to see I'm not the only crazy guy with 2 Internet connections ....
