Is http://www.bwired.nl/domoticaworld.asp stuk?
Ik mis een hoop huisjes op de kaart. (Ik zie er nu maar 4.)
De TechGeek data staat er wel!.
Als ik b.v. mijn data kies zie ik die ook op de "map", maar de Google map is er dan weer niet.
PS. http://www.bwired.nl/domoticaworld.asp is nog steeds heel traag!
Is domoticaworld.asp stuk?
Moderator: TheHogNL
Right I will check it out!
Works again, I upgrade my MYSQL database and the decimal point in the GPS value somehow disappeared
users will be back after each next upload.
About the performance, its on my todo list. building the XML and read it in googlemaps takes a long time.
will make another setting
Should be much faster now, please try.
thanks
thanks
Yes. It works again, but still not really fast (for me)
I think that you will need to "kill" all the table data that is shown below the map.
The page (when loaded) is for me 108KB.
Without the table data you can bring it back to +/- 14KB
OK try it now, I killed the table.
Yes.. Way faster now
Ok Thanks, I leave the table out.
