I see some X10 remotes have an DIM function. The log shows 'N1 ( General KR19A-1) N Dim 14' where N is the house code. Can these buttons be used within homeseer to trigger events or dim lights?
Jeroen
Dim function on X10 remotes
- Jeroen Bartels
- Jeroen Bartels
Nobody knows?????
Is it possible to trigger events by using these buttons?
In Homseer you can select trigger type: Received X10. By command you can select Dim, so I gues it will work.
Did not test it.
Did not test it.
