Cable Visonic Powermax Pro
Moderators: Rene, Willem4ever
nicobermejo
Post by nicobermejo »
I have a VISONIC POWERMAX PRO and I am trying to do myself a cable in order to communicate with the software (between rs232 pc and powermax).
I would like to Know the pins fron the poermax pro panel:
After that I think I must connect with RS232 converter to TTl:
I think if I Know the pins in panel powermax, I could connect to pc.
Please, has someone experiencie on that? Do you think am I right?
someone know the pins from powermax pro?
Thanks
Snelvuur
Post by Snelvuur »
dont you also need a small module installed in the powermax to even be able to communicate with it? Like on the picture below..
nicobermejo
Thanks snelvuur,
I am trying to do myself this small module. This module is only for converter signal TTL --- RS232 (by RJ45).
With max232 I think I could the same but I need to Know the pins in the board:
+5v
GND
RX
TX
Thanks in advance
nicobermejo
I see in other Topic:
Concerning the wiring-diagram, have a look at the MAX-232 datasheet. Looking at pictures of the PCB the circuit-board is a very standard TTL <--> RS-232 convertor.
Looking again at the PCB:
1: +5V
2: RX from PowerMax to external
3+4: TX/DTR from external to Powermax
All signals TTL level
Please could you confirm these pins in your small module with a multimeter?
Thanks
nicobermejo
Tis is the part of your small module:
Thanks in advance if you could confirm the pins:
+5v
GND
RX
TX
Snelvuur
Post by Snelvuur »
i dont know that, perhaps bwired/chak knows..
