Is it correct that the combi of a transmitter and reciever isn't available anymore from rfxcom?
Is there a alternative?
No combi transmitter-reciever anymore?
They're still there:
http://www.rfxcom.com/transmitters.htm#Transmitters
Optionally you can put in up to 2 receivers as well.
The combi has been taken of the shop. I asked the same question and received this answer:
The LAN rec/transmitter combination with one order number has been removed.
For the LAN/WLAN interface with a receiver and transmitter select a LAN/WLAN receiver interface and add a transmitter module.
http://www.rfxcom.com/receivers.htm#80002 select here the LAN version then
http://www.rfxcom.com/transmitters.htm#70031 or http://www.rfxcom.com/transmitters.htm#89031
I should go for a 2port version. Otherwise i can not add a transmitter module.
Thanks for the information.
