I'm trying to add my virtual COM ports to connect to my RFXCOM 2-port module. I've created COM6 and COM7. The creation of COM6 works like a charm. When I try to add COM7 I get the error "Parameter incorrect". I was wondering if anybody has seen this before and how it can be solved.
Creating COM8 (or any other port) instead of COM7 does not solve anything.
COM Port Redirector
COM Port Redirector
Why don't you use direct ehternet?
New feature in the rfxcomplugin!!
Ruud
Ruud
- b_weijenberg
COM Port Redirector
See chapter 6.3 http://www.rfxcom.com/documents/Quick_S ... meseer.pdf
The new version 14 of the RFXCOM plug-in will become available in the Updater next week.
COM Port Redirector
@Ruud: I installed the plugin from HS, which does not have this feature yet (its an aolder version). I've installed the version from Bart, which works like a charm
Thanks
Thanks
