Hi All,
I like to monitor my doorbell via MCT-100 and RFXcom receiver.
when i connect the doorbell to the MCT-100 there is directly a signal transmitted all the time.
what do i have to do for monitoring..
did play with the jumpers but without any success.
is anyone els using the MCT-100 for doorbell monitoring?
Enver
MCT-100 Doorbell
- Willem4ever
- Global Moderator
MCT-100 Doorbell
Hi Chak,
I use a MCT-100 for doorbell and mailbox monitoring. Look at the attached drawing on how I connected the doorbell.
MCT-100 Doorbell
Hi Willem,
thank you for the information.
Enver
Enver
MCT-100 Doorbell
Hi Willem,
I have done the modification with some help
Only problem i found out is when the doorbell is pushed for short time then the MCT-100 will not notice that.
How did you solved that problem?
