So I figured, first I would add the qees device to my controller (aeon z-stick) which also went fine. Then come the issues: when I imported the device into it showed up as a generic controller, a battery status entry and a scene controller conf entry (which HS doesn't seem to support?)
I figured this was wrong, and instead of adding the device to the Z-stick and importing I figured I would add it via HS directly.
So then I noticed there were no instructions on how to exclude the qees ring directly from the controller (using the include method doesn't do anything) - if I used the send Node info command on the qees ring the Z-stick did respon, but it was still not excluded
So then I decided to do this via the HS remove node option - but in the same menu it seems to add it again after removing it? :
DONE - Remove Node Operation is Complete.
Done. Checking for corresponding devices in HomeSeer to be removed...
Reloading (importing) node information from the controller...
The Z-Wave network has 8 nodes.
I've tried resetting the qees ring, removing and re-adding it various different ways, but whatever I do it stays registered on the controller (the number of nodes never changes from
How do I remove the qees ring from the Aeon z-stick? and how do I add it to HS properly so I can use the individual buttons to drive events (I do not want to associate the qees ring directly to the other z-wave devices as I want to drive other things as well?)
Cheers,
Elco
