Status icon in Homeseer
leo
Post by leo »
I have been a few days working on my set-up in Home Control Assistant to transfer to HS and HST. HS is not a logical mi of design and structure and I also walk to several problems;
1) In the devices list, I have an MS13 motion sensor but it is included in the HS status screen appears as a lamp. Is it possible to change the bulb icon in a motion sensor icon.
The same with the appliance modules. These are the status display by a lamp. Are these icons also change (in the machine what you want the appliance module driving)??
2) If I activate motion sensor or with my remote control or turn off a lamp I see no change in my status screen (the icon lamp as the motion-sensor-now is not represented on or off). If you then use the refresh button I see the status change. Is it possible to refresh automatically this to happen as a kind event that is triggered by an action of a device or something like??
Alexander
Re: Status icoontje in HS
Post by Alexander »
Leo,
This forum is in English. So i will respond in English.
1) you'll need additional plugins, like from blade (search on internet combine with homeseer)
2) not possibile. It's a website and webbrowsers can only update the page when a interval has been expired or if there is a continue get stream to the webserver. That isn't the case with HS (HST is). The device itself should change it status within homeseer.
Does my answer help?
Edit mod Dit is niet een engels forum!!!!
Alexander
It is possible to let Homeseer refresh the status screen at a specified interval. This interval can be specified via the setup-> Webserver tab using the option 'Auto Refresh (Seconds 0=No Refresh):'.
leo
Re: Status icon in Homeseer
Post by leo »
Rene, Alexander,
Thanks for the replies to my questions. Here is another one:
I've made an event which switches OFF my schuifpui lights at 23.50 hrs. But I only want this to happend when I am running the event "vacation" which is triggered by a switch F5 at my frontdoor. As things are now in HS every day the lights will switch OFF at 23.50. How do I have to programme HS that this particular event only happends during the "vacation" event".
rgrds, Leo
You should add a condition to the trigger for your switching lights off event based on the status of F5 (F5 = on).
leo
Post by leo »
Rene, quick reply!!. Thanks....I really have to get used to the HS way of "thinking". It''s completley different then the programma I am using right now and I have lots of events to be rewritten in HS...
rgrds, Leo
