I have a small problem with the forum.
At the moment I log into the forum with my account and while I select automatically logged on (see picture), I log within a few seconds out (especially when I use the back button) .
I have been on done it multiple PCs but the same problem.
Is this a setting somewhere in my profile that I should change?
I like to hear it.
Grtz,
Dieuwert
Inlog problem
Moderator: TheHogNL
Re: Inlog problem
Interesting. I don't recognize this problem.
Are all those pc running the same browser and version, by which is?
Alexander
Re: Inlog problem
I use at this moment IE8 (see screenshot).
I have install now chrome and sofare it's normal working, tonight i'm looking on my other pc what the version is of IE mayby it's a update issue.
I still inform you.
Grtz,
DJ
I still inform you.
Grtz,
DJ
- IE8.jpg (41.17 KiB) Viewed 6424 times
__________________
Re: Inlog problem
What about cookies?
I think the login is remembered in a cookie, with a little bit of security on cookies might be deleted.
Regards
Morten
(I use IE8 with cookies allowed, no problems here.)
Regards
Morten
Re: Inlog problem
We don't seem to be the only forum with this problem: http://www.phpbb.com/community/viewtopi ... 65&start=0
Did you try compatibility mode/view? http://blogs.msdn.com/ie/archive/2008/0 ... -view.aspx
Re: Inlog problem
This seems to work with the compatibility mode on.
But I must say that this forum is significantly slowed when this mode is on.
__________________
Re: Inlog problem
I haven't changed my settings recently, and the forum has been slow for a while.
