As promised, here is the next release with some minor additions and some fixes.
I hope i haven't missed any of your reports the last couple of days or forget to fix something; if i did, just help me remember
Have fun!
Moderator: RdP
Same problem here, phonebook is not loading any entries out of my FRITZbox phonebook.TANE wrote:Robert, Phone-book of Homeseer fbf is not showing any user name
reload is also not loading any name from fritz-box
Verion 0.76 is frtixbox version
31-1-2010 0:42:05
31-1-2010 0:42:05
31-1-2010 0:42:05
31-1-2010 0:42:05
31-1-2010 0:42:05 Loading INI Settings
31-1-2010 0:42:05 Hostname = 192.168.1.1
31-1-2010 0:42:05 DebugMode = True
31-1-2010 0:42:05 Devices = 5
31-1-2010 0:42:05 UnknownCaller = unknown caller
31-1-2010 0:42:05 AnonymousTrigger = True
31-1-2010 0:42:05 DeviceStringFormat = %D %N %TM
31-1-2010 0:42:05 Split Calls = True
31-1-2010 0:42:05 Search for Names = True
31-1-2010 0:42:05 Database = C:\Program Files\HomeSeer HS2\data\FBF\FBF.mdb
31-1-2010 0:42:05 Database Found = True
31-1-2010 0:42:05 Searching Phonebook for: 06531*****
31-1-2010 0:42:05 Database : C:\Program Files\HomeSeer HS2\data\FBF\FBF.mdb
31-1-2010 0:42:05 SELECT Name FROM PhoneBook Where [Home] LIKE '%06531*****%'
31-1-2010 0:42:05 -1
31-1-2010 0:42:05 SELECT Name FROM PhoneBook Where [Mobile] LIKE '%06531*****%'
31-1-2010 0:42:05 SELECT Name FROM PhoneBook Where [Work] LIKE '%06531*****%'
31-1-2010 0:42:05 Searching Internet for: 06531*****
31-1-2010 0:42:06 No match found...
31-1-2010 0:42:06 Searching Phonebook for: 06531*****
31-1-2010 0:42:06 Database : C:\Program Files\HomeSeer HS2\data\FBF\FBF.mdb
31-1-2010 0:42:06 SELECT Name FROM PhoneBook Where [Home] LIKE '%06531*****%'
31-1-2010 0:42:06 -1
31-1-2010 0:42:06 SELECT Name FROM PhoneBook Where [Mobile] LIKE '%06531*****%'
31-1-2010 0:42:06 SELECT Name FROM PhoneBook Where [Work] LIKE '%06531*****%'
31-1-2010 0:42:06 Searching Internet for: 06531*****
Jep!TANE wrote:Is the int. firmware 58.04.78 available?
