Not sure wher to place the topic but here it goes.
To get the right information on the right chart you need to use the point corresponding chart numbers to the device done in rfxcomm plugin.
For example (these are the ones i know, anyone for the rest?)
enviro 1 you need sensors on chart 10
enviro 2 you need sensors on chart 11
enviro 3 you need sensors on chart 12
But now for the weather. I use a BTHR918N (chart 11) in the livingroom for the baro function and for the temp&humid i use a THGR228N (chart 10) that's placed outside.
In the current view i can see the correct temp/humid?baro values but wehen i select daily or monthly i see nothing?
Must be a simply solution but what
which chart numbers to use with ph charts
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
