which chart numbers to use with ph charts
Posted: Mon Feb 15, 2010 8:45 pm
Not sure wher to place the topic but here it goes.
To get the right information on the right chart you need to use the point corresponding chart numbers to the device done in rfxcomm plugin.
For example (these are the ones i know, anyone for the rest?)
enviro 1 you need sensors on chart 10
enviro 2 you need sensors on chart 11
enviro 3 you need sensors on chart 12
But now for the weather. I use a BTHR918N (chart 11) in the livingroom for the baro function and for the temp&humid i use a THGR228N (chart 10) that's placed outside.
In the current view i can see the correct temp/humid?baro values but wehen i select daily or monthly i see nothing?
Must be a simply solution but what
