Visonic device types
kalimaro
Post by kalimaro »
Can i distinguish the different types of Visonic wireless devices using Powercode by looking at a specific bit in one of the received bytes ? I see that the demo program does this when running the code in variable length mode, but not in Visonic mode. Why or what bit?
Thanks
Brgds
Kalimaro
b_weijenberg
Post by b_weijenberg »
The packet layout is fully described in the documentation that is delivered with the receiver.
kalimaro
Post by kalimaro »
I can not see any documentation on the difference between types.
I want to see if it is a motion sensor or a door sensor....
b_weijenberg
Read chapter 9
kalimaro
Post by kalimaro »
Not sure what PDF file you are reffering to ?
Snelvuur
Post by Snelvuur »
I would think the one at www.rfxcom.com
You can also check the code of the Receiver program, in that code you can exactly see what is possible with received bytes patterns.
b_weijenberg
The RFXCOM Visonic document I'm refering to is not available on the web site but delivered with the receiver.
