CM15
Moderator: RDNZL
hotwater
CM15
Post by hotwater »
Can I use the CM15pro (marmitek) with domotiga?
thanks you
j.hoekstra
Re: CM15
Post by j.hoekstra »
Afaik domotiga only supports X10 via Heyu or via RFXCom, and according to the heyu FAQ the CM15 Pro isn't supported.
smarthomer
Re: CM15
Post by smarthomer »
It wood be nice if I can use my marmitek CM11 controller
j.hoekstra
Re: CM15
You can, I use the CM11 from elekhomica for this.
You'll need to build/ get Heyu on the same machine & then point domotiga to it. Look @ the the domotiga website for more info.
smarthomer
Re: CM15
Thank you, it works great (for a X10 system) and easy to setup.
Return to “DomotiGa Forum”
