Maximum possible power to measure with S0 output
Frank
Post by Frank »
I am currently writing some software in a uC in order to keep track of several S0 outputs of kWh meters (S0 according to EN 43864).
My question is the following:
Almost all suppliers define a pulswidth of > 30ms. So the maximum amount of pulses per second will be around 30 (1000ms/30ms). Let's assume a meter with 1000 impulses/kWh = 1 impulse/Wh.
Now the maximum I can measure in 1 minute will be 30 impulses * 1 Wh/impulse = 30Wh. This equals to 30Wh*60 minutes = 1800W
So if I connect a load of 1800W to my meter, it will generate 30 impulses/minute. What happens to the pulses if I connect a larger load? I understand the number of pulses will go up, but how about the pulsewidth of the S0 output? When each puls is 30ms, it is not possible to measure more than a load of about 1800W.....
Can anybody help me out?
Frank
A load of 1800W generates 1800 pulses per hour, since 1800W for the duration of 1 hour = 1800 Wh.
So you get a pulse every 3600/1800 = 2 seconds.
So where's the problem? I think you mixed seconds and minutes somewhere...
Robert
Frank
Post by Frank »
Hi Robert,
Thanks for your prompt reply. I knew something was wrong, but not that it was that stupid......[xx(]
This is obviously the sign that I need some sleep.
Thanks again for your reply.
Frank
