because the powermax pro is not to be prgrammed by powerlink i bought a set powermax remote programmer.
i bought the powermax pro in brittain and the remote programmer in holland.
;but on trying to contact the powermax pro he gives the error report
the table definitions for the control panel [4,8 ]model have not been found
i have contact via the serial connection with the powermax pro if i give the wrong download code with the log in he returns : acces denied.
i intalled the remote programmer software on a vista computer and on a xp pro with normal serial port, the eror repor remains the same.
i even resored the orriginal installer codes in the powermax pro , but the problems remains.
does anyone know where the problem is ?
programming powermax pro , error trying to contact
Moderators: Rene, Willem4ever
- Snelvuur
Re: programming powermax pro , error trying to contact
the powermax controller needs a com1 or com2 port at least it needed it with me, otherwise it didn't work. so make sure you dont have one in a high range.
did you first uploaded the alarm config to the pc?
** edwin **
it works as a train with the newest version of the programmer software: 30.0.40.4
jilles
jilles
Where did you get this version of the software? Can you upload it to the forum?
** Maurice **
- Snelvuur
That was a hard google.. (meaning, it took me more time then usual to find it)
http://www.waakzaamwonen.nl/pmsoftware.zip
