Just facing a very strange problem with squeezebox server installad on a virtual machine.
Current setup :
Hp server
- running with small business server 2003.
- installed virtual box on the sbs 2003
- create a virtual machine with win xp
- installed squeezebox server on the win xp vm machine
Testing phase 1
- connect squeezebox server from a physical machine true website ( works okey)
- connect squeezebox server from a physical machine with squeeze player ( works okey)
- connect squeezebox server from a physical machine with softsqueeze( works okey)
On virtualbox
- Install squeezeplayer
- install softsqueeze. ( java and java mp3 codec)
Testing phase II
- ping to squeezebox server ( works okey)
- open rdp session to squeezebox server ( works okey)
- connect squeezebox server from a vm machine true website ( works okey)
- connect squeezebox server from a vm machine with squeeze player ( Not working - can't connect squeezebox server)
- connect squeezebox server from a vm machine with softsqueeze( works okey)
Testing phase III
Disable all firewall settings on vm machine
- Same conclusion as testing phase II
Any ideas ...?
Thanks in advance
Marco
