heating thermostat wireless
labium
Post by labium »
i have a simple thermostat with on or off 24v relais for the fuelburner vaillant gas europe.
a mouse ate the wire in the basement.
i can't acces the basement except if i make a hole in a concrete floor.
is it posseble to use the SM10 Universal X-10 sender on the thermostat and the UM7206 Universal receiver on the fuelburner to make a wireless on/off contact ?
jilles
b_weijenberg
Re: heating thermostat wireless
Post by b_weijenberg »
You can also use the Digimax with RTS10 http://www.elekhomica.nl/product_info.p ... cts_id=617
The Digimax can be received by the RFXCOM 433.92 receiver and the RTS10 can be controlled by the RFXCOM 433.92 RFXmitter and transmitter. This enables you to use Home Automation software to control your heating unit.
