I'm pretty new to this RFXCOM stuff and I've been wanting to get a setup that monitors the room temperature in my living room. Additionally, I'd also like to be able to log the outside temperature and wind /-direction.
After some research I've come up with the following setup, which I'd appreciate feedback on:
- RFXCOM receiver ( 81003 see below)
- Type-3 RFXSensor (this one will be monitoring the living room temp. see below)
- Oregon Scientific WTGR-800 sensor (outside temp. + wind + humidity)
First question, looking through the forums and the RFXCOM website, I'm still a little confused as to what is needed. I get that I need a receiver ( w/ LAN) but I'm not sure what I'm getting. If I understand correctly,to receive both the Oregon sensor and the Type-3 I'd need the 81003 receiver plus the 80011 extra receiver module, right?
Second, in the future I'll be adding a second 81003 receiver that will allow me to monitor the utilities (gas, water, electricity) using the RFXMeter w/ RFXpwr. I understand from their website that I need an additional 2 optical sensors AND 2 RFXPulse modules to monitor gas and water usage, correct?
Finally, in the distant future, I'd like to add a water meter to monitor my hot tap water usage as well. For this, I can then add a second 80011 receiver module in the second 81003 receiver for the RFXMeter w/ RFXPulse module (70095), correct?
That would result in a setup of 2 81003 receivers, both with a second 80011 receiver module. One with both the 70095 RFXMeter and the 70087 RFXMeter, the other with the Type-3 RFXSensor and the Oregon WTGR-800.
I think I got it correct, but since it's all a little hazy when trying to figure it out, I'd appreciate some feedback from the professionals and correct me if I made a mistake?
RFXCOM and weather / temperature info
- b_weijenberg
Re: RFXCOM and weather / temperature info
RFXCOM likes your idea to order multiple receivers of the same type but this is not necessary if the sensors to receive are all within range of a receiver.
If you also want to control KlikAanKlikUit, HomeEasy or Harrison curtains in the future it is better to order the 83003 2 port LAN 433.92MHz receiver so that you can add a 70031 or 89031 transmitter module at a later time.
The 83003 receiver is able to receive the RFXSensor, Oregon WTGR800 and RFXMeter.
The 70087 RFXMeter + RFXPwr can have the 2 additional 70090 RFXPulse modules installed for gas and water.
The gas meter needs to have a small mirror on the least significant counter wheel. This mirror is on the 6 or the zero digit. For this you need the 70091 reflective optical sensor. If the gas meter has a reed contact you need the 70092 open-end cable to connect the reed contact to the RFXPulse module.
The water meter need to have a reed contact and you will need the 70092 open-end cable to connect the reed contact to the RFXPulse module.
OK, thanks for that clarification. I think I know what my thinking mistake was. Anyway, I've been taking a closer look at my water and gas meter and the gasmeter is lacking a reflective surface... I've also looked at the casing but I doubt it has a reed contact, or a location to put it. I did find a pulse module for a similar type of meter, but mine is old (1985, G4 Rombach) and I can't find anything confirming this pulse module can be used with my meter.
My water meter does not have a reed contact, but it does have a small wheel - like a sprocket - that is reflective with a red triangle on it. It also has a tine hole in it near the edge that passes over a small black area once every revolution. Would that be enough of a difference for the optical sensor, or is it not strong enough for that?
- b_weijenberg
It is difficult to say if the water meter can be monitored and the only way is to test it.
