buffer overflow
Bastiaan
buffer overflow
Post by Bastiaan »
Hoi Bert,
Lately I am getting 'RFXCOM bufferoverflow' messages in the logs. (no other errors visible)
Running
HSPRo v.66
RFXCOM v.65
two units over network, both with one TX and 2x RX.
I noticed that my whole HS system was then running at 100%CPU. This happens after one-two weeks running.
I have updated HS to the latest .72 build to see if it is a HS issue or also related to the RFXCOM plugin.
Just to keep you up to date.
Bastiaan
b_weijenberg
Re: buffer overflow
Post by b_weijenberg »
Bastiaan,
The RFXCOM plug-in does not get time slices to run due to another HS process that takes all CPU time.
The TCP/IP thread receives data and if the RFXCOM plug-in is not able to empty the receive buffer you will see the buffer overflow message.
Bert
Bastiaan
Re: buffer overflow
Post by Bastiaan »
Thanks Bert, thought it would be HS itself. Hope thet new HS version runs better.
