the rfx security inputdevices screen finds more visonic sensors than i have.
does the panel powermax pro transmit messages ?
does the wirelless sirene transmits messages ?
do the cameras transmits messages other dan wifi ?
other devices ?
security inputdevices and visonic
- b_weijenberg
Re: security inputdevices and visonic
Only Visonic sensors are processed. Other devices like the panel are not visible.
If you have enabled the AUX contact in the door/window sensor it will be received as well.
Check your neighbor if he has installed a Visonic system.
