I have an OWL cm119 that shows too much power consumption. So I thought that I could try to use the Calibration function when I edit the device.
When I try to calibrate it with an decimal number as Divider1 ie 1.64, and choose Save, it rounds it up to 2. I can see that it calculates the numbers correct when I punch in the decimals, but when I hit Save, it returns calculations based on 2 and not 1.64. Could you please make it accept decimal numbers? That would be great
