qees smartgate
labium
qees smartgate
Post by labium »
this is what i mean with tcp/ip connected domotica systems, this router will come soon i hope, but other quees products have been postphoned 20 times if i read other threads well.
it is only not clear to me if the z-wave part is reachable through the wlan port and lan port through ethernet.
the z-wave functionality is to be bought extra like a module of elektonica or flash card or a usb stick.
it is not to be bought yet.
http://www.ezhome.nl/nieuw-binnen-gekom ... tgate.html
mhn
Re: qees smartgate
Post by mhn »
I tried to Google translate. Didn't understand the question.
If you ask in English, I might know something. :-)
labium
Re: qees smartgate
Post by labium »
jeg can taler dansk
i dont know if this is correct danish but i lived 5 years in danmark virum near koebenhavn.
labium
mios vera 2
Post by labium »
this is also a z-wave tcp/ip gateway with z-wave server functionality, the latter i dont need i use homeseer but it is ment to be controlled by iphone etc all over the world so it can also be reached by my homeseer server, but i dont know if a plug in exists i have to look further .
labium
mhn
Re: qees smartgate
Post by mhn »
The QEES gateway will be among the first products hopefully around august.
It will come with one module, so there should be no need to buy extra, if you only want Z-Wave.
It is meant as a master, so the thought is, that it replace Homeseer. But there will be an open programming interface, so I think, you can control it from HomeSeer, if you wish.
It can be controlled from the Internet.
(I have not seen one powered up.)
Regards
Morten
So i can write you in danish from now on? ;-) (Jeg kan tale dansk.)
Return to “Z-Wave Forum”
