when i use the rfxcom commander ( or the x10 commander) and i send a ON command in x10, it is ok
when i send a OFF command, it's ok for every value betwen A1 and A8,
but for A9 ---> A16 the value received is A1-->A8
I have the same trouble with they other letters.
here are the logs from domotiga
A9 X10 on (using the rfxcommander)
[RFXComTX] 20649B10EF
[RFXComTX] ACK=>33
--> A10 on
A9 x10 off
[RFXComTX] 20609F30CF
[RFXComTX] ACK=>33
--> this value is A2 off
Version request to xmitter => F030F030
xmitter Firmware Version: 44
version rfxcom . 11201 version 44 (tranceive/ receiver with lan interface)
domotiga 0.1.197
Who can help me ?
i see on the souces; there is case for value greater than 8 in the module CRFXcomTX, but i m not good enough to understand.
thanks by advance
best regards
Nicolas
Trouble with RFXcom with some x10 command
Moderator: RDNZL
- RDNZL
Re: Trouble with RFXcom with some x10 command
Hi I completely overlooked this post.
I will check/fix it soon!
Regards, Ron.
