Data barometer and rain rate
Wim2008
Post by Wim2008 »
Is it possible to read in the data from the barometer and rain fall with the RFXcom in homeseer?
In the RFX charts in Homeseer you can see a graphics from temperature and the humidity from several sensors. I understand that it isn't possible to read the data from wind direction or speed. See: http://www.domoticaforum.eu/viewtopic.p ... ind#p43654.
If that is not possible, is there an easy way to show the data from those parameters (Barometer, wind direction, wind speed and rain rate) in HStouch.
B.R. Wim :) :wink:
Wim2008
Re: Data barometer and rain rate
Post by Wim2008 »
Is there some info about sampling the data and show it in graphics on the forum?
B.R. Wim :)
