Homeseer RFXCOM plugin error
stefxx
Post by stefxx »
When I go to the Homeseer RFXCOM plugin page (http://localhost/RFXCOM/RFXCOM.asp) I get the following error:
System.Runtime.InteropServices.COMException (0x80010007): The callee (server [not server application]) is not available and disappeared; all connections are invalid. The call may have executed. (Exception from HRESULT: 0x80010007 (RPC_E_SERVER_DIED)) Server stack trace: at System.RuntimeType.InvokeDispMethod(String name, BindingFlags invokeAttr, Object target, Object[] args, Boolean[] byrefModifiers, Int32 culture, String[] namedParameters) at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams) at Microsoft.VisualBasic.CompilerServices.VBBinder.InvokeMember(String name, BindingFlags invokeAttr, Type objType, IReflect objIReflect, Object target, Object[] args, String[] namedParameters) at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at Scheduler.hsapplication.Plugin(String pi_name) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at Scheduler.hsapplication.Plugin(String pi_name) at RFXCOM.Page_Load(Object sender, EventArgs e)
The last thing I changed (as far as I can remember) is that I changed the IP address of my RFXCOM (both on the RFXCOM and in Homeseer offcourse).
All devices seem to work fine, no error messages during normal operation. But I can't configure any RFXCOM setting anymore...
Thanks in advance.
stefxx
Re: Homeseer RFXCOM plugin error
Post by stefxx »
Reboot helpt overigens niet. Een upgrade naar .84 ook niet...
En bedankt voor het verplaatsen naar het juiste forum :oops:
b_weijenberg
Post by b_weijenberg »
wat gebeurt er als je via Setup - Interfaces - RFXCOM op de config knop drukt?
stefxx
Post by stefxx »
Toen ik dat gisteren probeerde kreeg ik exact dezelfde error. Maar nu ik het net opnieuw probeerde was de error verdwenen!
Geen idee, ik heb niets veranderd, ben alleen een dagje weggeweest...
Bedankt! Alles werkt weer!
