Düwi rolo switch
ralhop
Düwi rolo switch
Post by ralhop »
is it possible to set different parameter times for up en down with düwi rolo switch?
my rolo´s use 27 sec. to go down and 29 to go up. now when I put with homeseer a dim level 0f 50% when the rolo`s are open they go down to 50% bur when i let them up again with homeseer to 100% the stop 10cm under the max. position.
has someone a complete parameter list of the düwi switches, just like there is of the düwi.me switches.
Ralph
xanhoera
Re: Düwi rolo switch
Post by xanhoera »
I decided to share my notes regaring the Duwi blind control here.
In theory, if I remember correctly, you should be able to do this by sending parameter 0 with values: 0x1B 0x1D.
ralhop
Post by ralhop »
Nice info, only i have the problem that 2 of my roloswitches are build in so i can't contol it by hand , so i want to use homeseer or an other program to control it with parameters.
Is it correct that you can control with parameter 0 both different direction times?
Ralph
xanhoera
Post by xanhoera »
ralhop wrote: Is it correct that you can control with parameter 0 both different direction times?
That is my understanding. I remember when fiddling around with it a while back, I've always sent twice the same hex value (in one decimal value) as the timings in my situation are the same in both directions.
One specific blind has operating time UP & DOWN of 33 seconds, which is '0x21' hex. So the value of parameter 0 is set to '0x2121', which displays in homeseer as decimal value '8481'
Return to “Z-Wave Forum”
