It seems I'm not able to associate both switches from this unit with Homeseer. Controlling them from homeseer works fine also the status is updated but when using the switches, only one switch is logged within Homeseer as root device status change and not child 1. The other switch will report nothing in Homeseer. I have tried all kind of combinations (also the recommended one of group 3 with Homeseer) but it seems that it doesn't work correctly within Homeseer.
Is there anybody who had success with this unit ?
FGS211 double switch and HS association
Re: FGS211 double switch and HS association
It is not FGS221 (Fibaro), but HomeSeer problem. Of course you can ask HST team about multi channel receivers support
but so long they give a sh... (as standard) in European marked, dont know if you will get any responce from them.
Maybe, next, v.3 of the HomeSeer will be better.....???
Tnx for the update. In that case I don't have to spend more time testing. Glad I just bought one switch and a lot of dimmers so I will rewire and use a dimmer in this case. Can sell this switch to a Vera user then ..
