Can i use a ELV MAX for instance? Are there external temperature readings then possible? Because they would be installed at the hub of my city heating where the pipes go towards these rooms. So it needs to have a temperature reading from somewhere else..
Or are there any other thoughts about this? Because now it just "slightly" heats up all 3 each time and then the house is warm but the floor tiles are still pretty cold. If i only heat the kitchen then the house is also warm but its nice and warm to the feet too
