airox wrote:Jrkalf,
What do you mean with S2? The second switch on the FGS221? If so, the manufacturer is the same code. But you need to know a bit how this works.
The FGS211 is one device with multi instance support and needs to be switched using the multi instance support in open-zwave. Switching it using basic command class only causes the first switch to respond (but maybe you can configure this on the device).
If you need more info about the module, I have one also implemented in my own software and running as shed/outside lights switch.
Greetings
Cool,
I'm crap at programming and I don't program at all. I just hammered this together from what I could reproduce from the domotiga support of Ron. And I also got this from the manual tonight. So the device only needs to pair once (using S1 or the B button). No need to pair the second port (S2) as well.
I will have to figure out how multi-instance support works in open-zwave and talk to Ron if he has time to eventually program this into the software.
I've just connected my "corner" setup with the idiotic concept of the previous residents of this house. On an open corner have a button on each side of the wall. So I had to figure out my cabling because internal routing wasn't possible due to the wooden framework in the drywall.
an overview:
