Full control over TV via RS232?
Posted: Wed Jan 25, 2012 11:24 am
by DJF3
While looking for a TV in de bedroom I ran into a model with an RS232 port.
(LG 32LV2500
lg.com/nl/tv-audio-video/televisie/LG-l ... LV2500.jsp)
(manual:
lg.com/nl/common/product/support.jsp?lo ... V2500.jsp#)
Page 110
This port can be used to connect to an external control device (like PC). What can be controlled?
- Screenshot of LG TV RS232 commands
- Screen Shot 2012-01-25 at 10.19.57 .png (107.66 KiB) Viewed 16414 times
This looks pretty cool.
So the Question remaining: (not that important)
WHY do I want to control remotely on a TV in my bedroom????? I need it but don't understand why
Help me..
DJ
Re: Full control over TV via RS232?
Posted: Wed Jan 25, 2012 1:17 pm
by Esteban
For the 'why', how about: So you can have it turn on in the morning when waking up? I know it's not much, but you have to legitimate it somehow, don't you?
Posted: Wed Jan 25, 2012 5:22 pm
by Bjochems
You can get a fully automatic live stream of your living room when somebody is breaking into your house
Posted: Wed Jan 25, 2012 6:29 pm
You can create a Homeseer event (not triggered by motion of course, but by a microphone that detects the snoring
) that will turn off the TV after you fall asleep.
Posted: Wed Jan 25, 2012 6:50 pm
by DJF3
<grin>
Posted: Wed Jan 25, 2012 11:50 pm
by structor
Easy, because you can, therefor you must
Posted: Thu Jan 26, 2012 9:27 am
by Noel
When your wife and you are making "special" moves (up/down), turn TV on and change to "preset" TV channel.
Posted: Thu Jan 26, 2012 2:49 pm
by labium
why , do you want domotica ? It is all in the mind, i think you want to take control. controlfreak ? OCS ?
the human why is not logical , has never been, will never be . we arent computers, nor machines, we feel, react by motivation not by buttonpress.
Posted: Sat Jan 28, 2012 12:53 pm
by DJF3
I got the TV
Do you know if there are HS plugins that can read/interpret serial data? Once the data is in HS I can write something to translate the data into readable info.
DJ
Posted: Sat Feb 04, 2012 8:55 am
by Droezel
Here's my script to control my sharp aquos tv in the bedroom:
Sub Main(parm)
'add spaces if neccesairy
Do Until len(parm) = 8
parm = parm & " "
Loop
Dim retVal
'hs.WriteLog "SharpTV", "Execute: [" + parm + "]"
hs.SendToComPort 14, parm + vbCr
hs.WaitSecs(1)
retVal = hs.GetComPortData(14)
'hs.WriteLog "SharpTV", "Response: [" + retVal + "]"
End Sub
Sub GetStatus()
' get the power state and update device V7
retVal = ""
hs.SendToComPort 14, "POWR? " + vbCr
hs.WaitSecs(1)
retVal = Trim(hs.GetComPortData(14))
If Instr(retVal, "1") > 0 Then
hs.SetDeviceStatus "V40", 2
Else
hs.SetDeviceStatus "V40", 3
End If
' update other devices, if powerstate is on, otherwise set all to off
If hs.IsOn("V40") Then
' get the audio state and update device V8
retVal = ""
hs.SendToComPort 14, "MUTE? " + vbCr
hs.WaitSecs(1)
'hs.WriteLog "SharpTV", retVal
hs.SetDeviceStatus "V41", 3
Else
hs.SetDeviceStatus "V41", 2
End If
'get the source input and update device V9, V10,V11
'retVal = ""
'hs.SendToComPort 14, "IAVD? " + vbCr
'hs.WaitSecs(1)
'retVal = Trim(hs.GetComPortData(14))
'If Instr(retval, "1") > 0 Then
' hs.SetDeviceStatus "V9", 2
'Else
' hs.SetDeviceStatus "V9", 3
'End If
'If Instr(retval, "5") > 0 Then
' hs.SetDeviceStatus "V10", 2
'Else
' hs.SetDeviceStatus "V10", 3
'End If
'If Instr(retval, "8") > 0 Then
' hs.SetDeviceStatus "V11", 2
'Else
' hs.SetDeviceStatus "V11", 3
'End If
'get volume level
retVal = ""
hs.SendToComPort 14, "VOLM? " + vbCr
hs.WaitSecs(1)
hs.SetDeviceValue "V42", Clng(retVal)
hs.SetDeviceString "V42", retVal
'hs.SetDeviceString "V12", ""
'get sleep timer
hs.SendToComPort 14, "OFTM? " + vbCr
hs.WaitSecs(1)
'hs.WriteLog "SharpTV", "Sleeptimer: [" & retVal & "]"
hs.SetDeviceValue "V43", Clng(retVal)
If retVal = 0 Then
hs.SetDeviceString "V43", "Off"
Else
hs.SetDeviceString "V43", retVal & " min"
End If
'get the channel
hs.SendToComPort 14, "DCCH? " + vbCr
hs.WaitSecs(1)
'hs.WriteLog "SharpTV", "Channel: [" & retVal & "]"
hs.SetDeviceValue "V44", Clng(retVal)
hs.SetDeviceString "V44", retVal
Else
' set all other devices to off
hs.SetDeviceValue "V43", 0
End If
'hs.CloseComPort 10
End Sub
Sub PowerToggle()
hs.SendToComPort 14, "POWR0 " + vbCr
Else
hs.SendToComPort 14, "POWR1 " + vbCr
End If
End Sub
Sub SetVolume()
Volume = Cstr(hs.DeviceValue("V42"))
If len(Volume) = 1 Then
Volume = "0" + Volume + " "
Else
Volume = Volume + " "
End If
hs.SetDeviceString "V42", Volume
hs.SendToComPort 14, "VOLM" + Volume + vbCr
End Sub
And here's a screenshot of some tv events, I have 2 sharp aquos tv's in the house.
- TV_Events.jpg (233.38 KiB) Viewed 16284 times
Re:
Posted: Sat Feb 04, 2012 12:47 pm
by aagesen
DJF3 wrote:I got the TV
DJ
Hi, take a look at this thread
http://board.homeseer.com/showthread.php?t=123350
Posted: Sat Feb 04, 2012 4:00 pm
by DJF3
Fantastic!
Droezel, thank you for sharing and aagesen, thank you for this link..
Just have to figure out what exactly I'm going to do with
DJ
Posted: Tue Feb 21, 2012 8:34 pm
by aagesen
And now there is a plugin too.
I'm markus on the homeseer forum so I'm the one bothering mrhappy. This works with my lg tv from 2009.
http://board.homeseer.com/showthread.php?t=152929
