IR Trans usb incl. irt-trans-hp [verkocht]
Paul H te O
Post by Paul H te O »
Verkocht:
IR Trans USB met IR-TRANS-HP
Incl. USB kabel.
IRT-TRANS-HP = External High-power IR Blaster
Prijs is 75,- Euro incl eventueel verzenden.
• Sends and receives IR Codes
• USB Interface for the PC
• Firmwareupdate via USB
• Connector for the IRTrans 2/3 wire bus
• Connector for external IR LEDs (Transmitter)
• White case
• USB Resume - wakes up the PC from S1 Standby
• Together with the PowerOn Option the IRTrans Module can switch the PC on and off.
• Optional with Universal IR receiver. Learns and measures ALL Carrier frequencies. Range: 1m
HS4 Windows 10 Pro
mo046
Re: IR Trans usb incl. irt-trans-hp
Post by mo046 »
je hebt een PM
** Maurice **
