Error cannot add script engines
John
Post by John »
All,
Since today I can not run any script. I get the following error:
Error Running script, cannot add script engines: A script engine for the specified language can not be created.
Before this error HomeSeer is doing the following:
17-2-2012 15:52:51 - System - Registering C:\WINDOWS\system32\msscript.ocx with Windows
Has someone seen this problem before?
John
xanhoera
Re: Error cannot add script engines
Post by xanhoera »
A while back I had similar error when trying to get python in homeseer working. I ended up installing another version of ActivePython, which eventually worked.
However, in your case, probably not python related, possibly something changed recently: windows update, virus scanner change?
John
Post by John »
I asume it was a virus scanner change.
After installing the image and a restore of the data everything is working fine.
