I've been heavily involved in Opentherm the last couple of weeks and today I reached a point where I can see light at the end of the tunnel again
I've built an Opentherm Monitor based on the good-old Elektor Opentherm Monitor article (http://www.hekkers.net/files/Opentherm.pdf) and modified it so I was able to connect it to a JeeNode.
But it didn't work as expected: decoding the Manchester signal resulted in too much errors on the JeeNode. Caused by different boiler and/or thermostat manufacturers all having their own timing issues, is what I can conclude so far...
So I went for another approach to decode the Manchester signal in a more 'adaptive' way and it paid off! No more errors. So if you ever want to build your own Opentherm monitor, this can be an interesting read:
http://blog.hekkers.net/tag/opentherm/
