After moving my server I'm having some problems with some of my Xanura modules.
I've added one SVX10, and this helped a lot, but some do still not work 100% (specialy when the TV is on)
Will adding another SVX10 cause problems? (Can two SVX10 be used within one system?)
two SVX10 in one system. Can this be done?
Re: two SVX10 in one system. Can this be done?
Yes can be done, but not close together.
Svx can also enhance the noise
Better is to filter tv and mediaset
I have a compleet filtered powernet and my x10/a10 is perfect
Also the driver is important, the driver which is available for Homeseer is a very bad one and mis a lot of X10 commands
Great.. So I'm going to order a 2nd SVX10.
re: Drivers..
What drivers are you talking about? The one for the PMIX35?
I'm using the "ACT TI103" from homeseer to control it.
re: Drivers..
thats a shit driver, if there is multiple X10 traffic, you start to loose command. For not much X10 traffic its OK
but for example lots of X10 devices or if you have X10 motion sensors its really bad.
Down side is that there is no other driver for Homeseer
I have 2x used SVX10 for you if you want 25 euro ps
You have a PM...
