RFXtrx433 and Sartano
Posted: Fri May 25, 2012 7:16 pm
I have just got my RFXtrx433 delivered and I am trying to use it. I have a remote controller named Sartano 2606 a.k.a. HN56002.
The only button that the RFX understands is the “D – OFF”. All the other buttons are ignored and thus no blinking yellow LED.
According to RFXtrx User Guide (http://www.rfxcom.com/documents/RFXtrx% ... 0Guide.pdf), Sartano is supported.
Using the RFXmngr tool, I get the following when pressing “D – OFF”
071001E74F100070
Packettype = Lighting1
subtype = ARC
housecode = O
Sequence nbr = 2
unitcode = 16
Command = Off
Signal level = 7
Firmware version = 40
Hardware version = 1.0
The DIP switch 1 is set to “on” in both receiver and transmitter and as stated above the DIP switch D is set to “on” in the receiver
Sending command=on with house code O and unit code 16 switches the receiver off though
All my Oregon sensors are recognized!
What can be the problem?
///Knasen
071001E74F100070
subtype = ARC
housecode = O
Sequence nbr = 2
unitcode = 16
Command = Off
Signal level = 7
///Knasen
