Homeseer Event Age - how to manage
DJF3
Post by DJF3 »
Team,
As I was working on a script that shows the age of events I found one by Jim Steed that was programmed way better. So I used that as the basis and added some features.
Original script: http://board.homeseer.com/showthread.php?p=1023020
Features Added
- Filter for Event groups
- Filter for minimum age
- Events ran in last 24hrs are gray (as they probably are less important for the purpose of this script)
- Lay-out changes
Features Added 0.6
- Removed event group column (displayed differently now)
- Fixed Age sorting
Download: http://www.domoticaworld.com/scripts/homeseer-event-age/
Re: Homeseer Event Age - how to manage
The link at the bottom should read domoticaworld.com/scripts/homeseer-even ... event-age/
Also the date sort isn't correct. It just sorts on the first number (all one's then all two's ect) and not on date.
DJF3
Post by DJF3 »
Yeah, the age sort has some challenges, have to find the time to look at that ;-)
Thanks for catching the link issue, no clue how that happened. (updated link)
A quick fix would be
- Transform the date to yyyy mm dd
- make sure that mm and dd are always 2 digits e.g. 03 instead of 3
Now a sort will give correct results.
When you get a bit creative you can also use DateDiff()
Use a fixed date to compare the date to that you want to test and use hours difference for example.
The larger the number the older the date is. :-)
You can use that in the same bubble sort routine you are using now.
DJF3
Post by DJF3 »
Thinking about this, I could also sort on the age which has the same result ;-)
DJ
So, why didn't do that in the first place... :-)
It's a nice maintainance tool.
DJF3
Post by DJF3 »
UPDATE: Just updated and published version 0.6.
- Fix for age sorting
- Removed "group" column.. Now events in 1 group are displayed differently (nice!)
- Some lay-out changes
DJ
