Hello
I have the new timer remote from Elro the AB600t but I can not make the timer function to work ie at a programed hour make the lights turn on I tried everything but with no avail this already the second remote
Reg.
AB
Help with the new Elro AB600t
Re: Help with the new Elro AB600t
I found out that you have to press the auto key to make the timer programs to work now everything is ok I also found that the keypad only lights up when one is in the dark I return the remote because I thought that the lights were not working well
the Elro support should known better
