Hi Forummembers,
I just playing with my Vera 2 controller and have different z-wave dimmers on it. ( Fibaro and HomePro )
Vera is running the latest firmware and UI5.
There must be a option for slow fade out the dimmers ( When I press the scene "All Off" than would that be nice is every dimmer is slowly fade out )
I'm working with other high-end lightingsystems as Lutron for example and that is easy to config/program that kind of things...
Somebody got a working Lua Loop for this? or is there a other option to do this?
Niels
Vera2 - Fade out slow with z-wave dimmers
- Starting Member
Re: Vera2 - Fade out slow with z-wave dimmers
Check the manual of the fibaro dimmer: you can set the steps of the dimmer inwhich it should level up and down.
If you say 25 than it goes directly from 0-25-50-75-100%
If you input 1 to goes 0-1-2-yougettheidea...
I dont know exactly which setting it is but I fiddled around with it and found that.
Factory default however is 1% so if you dont have this now, it is changed somehow by yourself....
- Starting Member
Ok, for Fibaro dimmers I can change it now in the device options... but that will be always the setting, not only for "Shutdown All"...
but it is much nices now... I only have a few HomePro dimmers active in my house.
But for the FIbaro it's a great solution!
Thanx for the tip!
Thanx for the tip!
