Is it possible for the SC9000 to emit a sound when the system is armed and I enter my house?
Because when there is no sound, I usually forget that the system is armed, and the alarm rings always...
I have the SafeGuard system
Thank you,
Samuel.
X10 Marmitek sound
- Starting Member
Re: X10 Marmitek sound
Yep. If you enter the house, there must a sound/light being generated. You have to buy a CM-15 Pro to make a macro. No CM 15, no sound so to speak...
Lets say, the house-code is A. The front-door is (example!) coded (A)-1 (security unit-number) Make a macro where code (A) 1 triggers the hall light (for example A-2) for 10 seconds or make it flash a few times. Done.
If you want to generate a sound, that's more difficult; I guess a lamp will do too.
Like to hear you got it right.
