i have this temp. sensor
clasohlson.com/no/Temperaturgiver-hygro ... r364288000
They did work fine before. I did move my HSpro to a another computer sence my old was broken.
Did copy over my old HSpro folder to the new computer. After i did this some of my Oregon senor didn`t work. I did delete them in hs and installed them again, but now i yust get temp sensor and battery status, not humidity?
Some of the sensor did work after i installed the new HS, but the humidity dosent refresh..
Hope someone can help me.
Oregon tempsensor does not show Humidity anymore?
Re: Oregon tempsensor dot show Humidity anymore?
They still dont show humidity....
did try to delete them form hs and RFXcom and reinstalled them, but still no humidity?
Any tips..
Any tips..
- b_weijenberg
Which RFXCOM receiver do you have in use?
I suppose there is an error in the plug-in if the TH1[xxx]H is not displayed on the RFXCOM Input dev config page and also not in the ADD list.
Contact support.
Contact support.
I`m using HomeSeer with the RFXcom plugin and i think you do also.
Do you see humidity message when u enable all debugging in the RFXcom plugin ?
I use TFA sensors and my log tells me this
28-11-2012 22:30:19 - RFXCOM - (display_T) Temperature: TH7[32014]T Device:\10 Value:7,1
28-11-2012 22:30:19 - RFXCOM - (display_H) Humidity: TH7[32014]H Device:\4 Value:85
28-11-2012 22:30:19 - RFXCOM - (display_L) Battery: TH7[32014]L Device:\7
Use RFXtrx433b_weijenberg wrote:Which RFXCOM receiver do you have in use?
Contact support.
No, i dont see humidity message when i enable debugging for RFXcomraymonvdm wrote:I`m using HomeSeer with the RFXcom plugin and i think you do also.
28-11-2012 22:30:19 - RFXCOM - (display_T) Temperature: TH7[32014]T Device:\10 Value:7,1 28-11-2012 22:30:19 - RFXCOM - (display_H) Humidity: TH7[32014]H Device:\4 Value:85 28-11-2012 22:30:19 - RFXCOM - (display_L) Battery: TH7[32014]L Device:\7
- b_weijenberg
Re: Oregon tempsensor does not show Humidity anymore?
please send a log file with debug level 2 enabled for the receiver to support
- b_weijenberg
It seems the sensor you have configured is an Oregon TEMP2 (THC238/268,THN132,THWR288,THRN122,THN122,AW129/131 sensor)
This type does not have a humidity sensor.
