Hi All,
i have a cm15 and a pmix35, when i use the cm15 i can reach al my x10 diveces, but when i chance to my pmix35 i can't reach all my divices.
is the cm15 stronger than the pmix15? and how can i make the signal of the pmix equal to the cm15
my configuration is homeseer an a x10 interface
gr marcel
pmix35
Re: pmix35
Are they located at the same place in your setting
Re: pmix35
yes,
they are at the same place, i just swap them
it looks that the pmix35 has les power
Re: pmix35
i have done some testings an i have find out that the pmix is sending on 0 degrees instead of 120
i have tried to make a serial connection whit putty, but i can not make a connection
can someone tel me the right settings, and am i using the right programm?
thanks
marcel
thanks
marcel
Re: pmix35
i think i have the problem solved
made some settings in PMIX network analyzer software
