SFX40 noise/block filters.. 3 * 72mm = very wide
Noel
Post by Noel »
Ben vandaag met een nieuwe zekeringen kast aan het stoeien, en aan het kijken of er ook ruimte is voor de 3 sperfilters.
Zijn die dingen van Xanura echt 72mm breed?
Never start anything you can not fi....
Please wifi in english!
only some forums like Homeseer are dutch all other english [^]
thanks
yes that is right
You can see it here, 3 x SFX40 mounted in the Eaton holec (Xanura Hifs35)
Noel
Post by Noel »
<br />Please wifi in english!
thanks
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Sorry about the klingon (Dutch) message..
Anyway.. The question was about the width of the filters (sperfilters), and if they are really 72mm each.
Thank you for the answer Bwired. I guess I need to create some more room for the 3 filters.
Noel
Post by Noel »
One more question for now.
As I'm on a 3 phase system, do I also need 3 times a fasekoppelaar?
No prob, forget it sometimes myself as well
and admins won't get bored :-)
Thanks
PS: you know there is a IEspell button which is very handy. just install the free plugin and you can use it everywhere.
Noel
Post by Noel »
<br />No prob, forget it sometimes myself as well
Thanks
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Is my English that bad?
PS: It's "an IEspell button" and not "a IEspell button" :-)
Snelvuur
Post by Snelvuur »
And you need a fase coupler too, but i think thats only 1 device. Pieter knows..
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Don't get me wrong [:I] It's just very handy.
BlaDeBla
Post by BlaDeBla »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by wifi</i>
<br />One more question for now.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"><font size="1">Hi all, I'm new to this forum. It's a very useful knowledge base</font id="size1"> [:)]
As far as I know, you need a coupler module for every phase.
At this shop they sell phase coupler which only needs one module. It doesn't include a filter/blocker.
http://www.elekhomica.nl/product_info.p ... cts_id=643
But they notice that the S4825 is intended for an X10 setup without micromodules. Today I sent them an email about this restriction but didnt received an answer yet. Anyone familiar with this module??
The same goes for the Xanura FKX phase coupler, you only need 1 fase coupler to get your X10 over the 3 phase powerline going. And it can handle all the X10 / A10 modules including micro modules. If you have a 3 phase powerline system and you need the noise/blocking filter SFX40 then you need 3 of them, 1 for every phase. I would start first with the phase coupler see how it works and if necessary add the SFX40 filters.
I have a Phase coupler running at Bwired on my 3 phase powerline and not yet SFX40 filters.
<b>Function FKX</b>
The phase coupler transmits Xanura signals that enter via one
phase to the other two phases. The signals are also amplified.
The signal on the phase from which the Xanura signal has been
received is amplified and transmitted on the same phase. The
phase coupler can also be used as a single phase signal
amplifier.
<b>Three phase connection FKX</b>
The phase coupler must be connected to a three phase group
with a maximum rated current of 16 A. It does not matter which
phase is connected to which core, as long as the blue core is
connected to neutral. The earth core does not need to be
connected, as it is not connected in the phase coupler either.
http://xanurahome-installateur.test2.bi ... dl_FKX.pdf
check also this topic: http://www.domoticaforum.eu/topic.asp?TOPIC_ID=491
Pieter Knuvers
