The application will allow up to 4 users with video/audio at one time (I can add more if needed, but need to test this 1st)
As it's still in test, and as I would love to see how some Bwired users look like (and show them how I look
If you feel up to it, go to http://chat.kijk.info , and login with a user name, and click 'Submit'.
With a bit of luck you will get connected to the FMS.
Now if you have a webcam, (and if any video channel is still available) click on 'start'.
Depending on how your flash is setup, you should see your webcam feed, or get a warning from flash that it wants to connect to your webcam. If the last, you will need to give it access.
Also depending on the way flash is setup, you should be able to talk (voice). If all fails, you can still type things in the small window at the bottom of the flash application.
Please give it a test run, and let me know what you think. I'm also open to suggestions on how to make it better.
I will leave my webcam connected, but I might not be all the time behind the PC.
See you soon on http://chat.kijk.info
One more thing. I've just set the DNS for it. You might get a error that the page can not be found. In that case try again later as the DNS servers might need a bit more time.
Never start anything you can't fi
